I'm replacing a bathroom at the moment, im not a pro.
I've recently replaced the taps on the existing bath with a mixer shower tap. The pipes that run around the room are 15mm cold and 22mm hot.
When I put the new mixer in I took a spur off of the pipes using 300mm x 15mm flexible connectors - so the hot steps down from 22mm to 15mm a foot before it gets to the tap.
The old hot tap had 22mm all the way up to about an inch before the tap where it was then reduced to fit the tap.
The old tap hot tap had really good pressure - the new tap has really poor pressure.......I'm just wondering what the science is behind this. It's not really an issue as the whole lot will be coming out and will be replaced......but obviously, I'd like to get the pressure right on the new bath.
