Hi
1st post, looking for a little advice from the professionals
...this rambles a bit, sorry.
30 year old gravity fed system died last month. Of the various options (fully pumped & keep old tank, big combi, or unvented) I went for what was advised as the "Rolls-Royce" solution: Vaillant branded unvented total system.
Problem
When I open 2 hot taps from the DHW unvented tank, I get a huge flow drop on both DHW outlets. 3 at one time reduces it to a trickle on 1 tap.
If I open 1 hot and 1 cold at the same time the flow drops through the floor.
It is currently not possible to use 1 shower and even 1 small mixer concurrently without a significant drop in flow. Opening 1 hot and 1 cold tap causes a similar problem.
1month ago I had quotes and surveys done by British Gas and another local firm. They found we had just under 4.0 bar static pressure at the garden tap dropping to 1.5~1.7 bar when the kitchen tap was fully open and a combined flow rate of 24-25l/min when garden, kitchen and cloakroom tap were opened concurrently. So my mains supply looks good???
So where do I stand? I reckon as installer's the competent person, he should have checked all of this out to his satisfaction prior to installation and he's liable for sorting this out.
I have paid 60% of the job already, but not willing to pay another penny until the job is complete.
Atmosphere is now a little tense after I emailed him my concerns.
If you were in this situation, what would you do as a pro?
Problem
