Good Morning All, I have a spring fed well half way up a hill and want to run a pipe from the well overflow (which is currently running out at c.2L/second. My idea is to start with a large bore pipe (c.110mm) and reduce it to maybe a 25mm pipe to create a fountain at teh bottom of the hill. However, I do not want to spend teh money and then see if it works, I want to calculate what size pipe I need to start with, at what stage I reduce it down to smaller bore pipes, how small a pipe a reduce to at teh end and how high the fountain will be?
