water pressure question re: shower?
21 Feb 2009
Hi
I may choose to replace my broken power shower with a thermostic shower control.
Is there any simple way in which I can check that the water pressure will be sufficent ro run this satisfactorily?
Cheers,
a good metre or so (in height) and probably 3 metres or so in distance
1 metre in height will only give you approx 0.1 bar.
won't be any good it'll need a pump on it.
Actually, I just turned on the power shower - ie - got the water flowing through it but without power/pump switched on - and the flow is acceptable.
Is this the 0.1bar of pressure you refer to?
thats a power shower not a thermostatic mixer valve.
thermostatic mixer will have more restriction than your power shower.
you can try it if your happy with the flow.
but most people like a nice powerful shower.
