Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
littlepig, that figure is pretty meaningless on its own. You might well have 2.5 + bar static pressure, but your flow rate might still be far too low for that shower. they might possibly mean that you must have 2.5 bar pressure at shower when its running, but you need to know flow rate through shower to begin to make sense of that. In general combi boilers will only work with normal shower valves running at up to 15 litres/min.
Edit 9.56 pm. - Just looked at your proposed set up. Forget it.
