I have a Permutit Metered Water softener (from B&Q) and it has been working fine for the last 3 years. Few months ago we let our property and 1 month after the tenants moved in they reported a unacceptable low water pressure if the water is going through the water softener and good pressure when they bypass it. My suspicion is that they have not added salt or they used a wrong type of salt which caused the problem. I called Permutit and the earliest they can dispatch an engineer is on the 10 September, 2007. In the meantime I would appreciate some advice on the matter as to what can really cause this problem because the water softener worked fine while we where living in the property and regularly added the recommended salt to it.
Thanks in advance for your help
