Hi I am looking for help with regards drawing water from a stream and passing it through a filtration unit and then pumping it into the house mains, and using that rather then AWA water.
I understand that I must have 45psi going into the main, and I need a pump which will deliver such pressure 45psi. Also I don’t need the pump to run continually for the power I use on the electricity will outweigh the amount I am saving on water A dilemma
thank you in antisapation of your help
Jeff (Woodland)
Jeff (Woodland)
