Waterproofing holes in wood
Discussion in 'General DIY' started by stealthwolf, 29 Nov 2017.
  1. stealthwolf
    stealthwolf
    20 May 2015
    578
    Thanks Received:
    36
    Birmingham
    Country:
    I need to ask a stupid question and my google-fu has let me down.
    Wooden door made from softwood. Varnished and protected. Need to drill holes for fixings. Fixings are all stainless steel.
    Do I need to worry about water ingress potentially rotting the wood inside? Should I use some sort of sealant prior to using bolts and screws?
    Or am i just overthinking this?
  2. Sponsored Links
  3. No you don't, and yes you are. Best of luck.
    • Thanks Thanks x 1
  4. foxhole
    foxhole
    14 Mar 2006
    18,231
    Thanks Received:
    2,093
    Kent
    Country:
    All hinge cut outs etc need varnish as well to seal entire door.
    • Thanks Thanks x 1
  5. stealthwolf
    stealthwolf
    20 May 2015
    578
    Thanks Received:
    36
    Birmingham
    Country:
    Thanks. sometimes, when I'm trying to sleep, my mind starts wandering. It was stuck in my head all day.
    Thankfully the hinges are not going to be recessed. Tee hinges so originally was going to screw them to the door. Then I thought about shoving bolts through instead.
  6. Sponsored Links
  7. big-all
    big-all
    12 Jul 2004
    19,156
    Thanks Received:
    1,513
    Surrey
    Country:
    what sort off door is this
    as in house garage or shed
    or would it be better describe as a gate ??
    is it smooth planed or treated timber ??
    • Thanks Thanks x 1
  8. stealthwolf
    stealthwolf
    20 May 2015
    578
    Thanks Received:
    36
    Birmingham
    Country:
    Side gate. Planed timber untreated.
  9. Sorry Stealthwolf, I should have checked where the door was being used first. You don't need to seal the screw holes, but using stainless steel screws would be a good idea if you go back to the using screws. But Foxholes right in sealing under cuts in the wood, and if you're using bolts, then yes, you've got an unsealed hole, but the bolts get tightened so should seal it back up.
    • Thanks Thanks x 1
  10. stealthwolf
    stealthwolf
    20 May 2015
    578
    Thanks Received:
    36
    Birmingham
    Country:
    Thanks. I was asking about the side gate but then when googling this issue, someone suggested swapping screws for bolts on shed doors for security reasons. So I tried to expand the question and make it more generalised.
  11. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
