Ways to watch Sky in another room...
20 Dec 2013
London
hi there
I just wanted to ask If anybody could please list the ways the watch Sky in another room
We have a main box downstairs and I wanted to know how I can watch in upstairs bedroom
I'm aware of
Wireless Video senders - remote facility included
Co axial / io method run cable all the way up and magic eye to control remote
But are there any others?
What is is this cat 5 balun thing all about?
Can anybody advise from own experience? I don't understand how Ethernet and hdmi's go together as I though Ethernet is to do with my modem if I want wires connection to lappy...
I have two HDMI cables running to each tv with a HDMI splitter (with amplifier) plugged into back of sky box. Your need to extend the IR too.
You buy a pair of devices which convert from HDMI to Ethernet, one at each end of the cable. The signal can then be sent over much greater distances compared to just using a long HDMI cable.
May work but are highly susceptible to interference from other devices both in your home and elsewhere.
Next to useless as you still have to buy additional devices and assumes you can find a channel which is not already in use and is not riddled with interference.
Get a second Sky box installed. Obviously this costs extra, but the equipment and installation for the other substandard solutions above isn't free either.
I was happy with my coax/ io link in my bedroom until I got a better TV.
The coax cable route works well but is limited in resolution. It is standard definition (SD) and basic mono audio regardless of whether the signal from Sky is SD or high definition (HD).
Budget/cheap Wireless Video Senders are also limited to standard definition. The signal connection port for them is either SCART or the yellow, red and the white phono sockets. Budget wireless senders range in price from £30 - £70
HD wireless video senders are available. The connection port is a HDMI socket, so you'll need to split the output from a Sky box to feed the TV and the HD sender. Prices range from £150 and up. Results with wireless senders are variable. The same product can work brilliantly at one house and terrible in another. The only way to find out is to try it. Be prepared for lots of hassle and returns.
If the distance involved is under 15m then a long HDMI cable will probably work. There are situations where I have run HDMI at 1080p longer than that, but I have used good cable and the signal hasn't been split at the source end. If you're working from a normal Sky HD box (not a Sky Q box at 4K) then the signal will be 1080i. That requires far less bandwidth than 1080p, so it's possible you might get it to travel 25m without too much issue. You may run in to problems though if you watch 3D movies via the On Demand service. That requires about the same bandwidth as 1080p. All bets are off if you're using a Sky Q box at 4K.
HDMI Cat Baluns are nothing to do with Ethernet. The fact that they use Cat5 or Cat6 cable is purely coincidental. The baluns do not convert the HDMI signal in to IP, so the signal cannot be sent via an Ethernet switch. Forget any ideas about cheaply sharing Sky's signal via inexpensive HDMI baluns and the Ethernet ports on your router.... it won't work.
Baluns convert the signal in to a more robust form that can travel down twisted pair Ethernet (Cat) cable. That's about it. There's a range of prices in baluns. Some of that difference is due to whether the baluns send the signal in uncompressed form; IOW better baluns give out what you put in so the resolution isn't affected. I have come across cheaper baluns that resample the signal (reduce the resolution) so that it will either travel further or will travel via a single Cat5 cable. You need to check that out before committing to buy. The rest of the price difference is to do with the range they'll support, and whether they include IR signal return, if they handle EDID memory, and then there's marketing. Some baluns are the same product sold under different brand names.
The advantage of baluns is range. A good running on a decent pair of Cat5 or Cat6 cables might work happily up to 50 or 75m. The same signal travelling by HDMI cable might struggle to do 20m.
HDbaseT baluns. These look like simple Cat cable baluns but there's a couple of really important differences. The first is that they're designed to work with simple Cat5 cabling, and often with just a single cable rather than a pair as with a lot of the basic HDMI Cat baluns. The second is that a lot of the decent HDbaseT baluns can be used with an Ethernet switch. That doen't mean you can mix these baluns with your internet connected devices through the same router. It is best practice to run a separate Ethernet switch for these AV devices and leave your wired and wireless connections to run in a separate system so that the two never come in to conflict. HDbaseT baluns used to be prohibitively expensive (£400+ per pair) but increasing competition and growing sales volumes is helping to push prices down.
Now let's talk about control....
All of the options listed above include variants that allow IR signals to be sent back down the wire to control the Sky box from the bedroom. With HDMI cable you can attach add-on IR Injectors which look like a little extension plug for each end.
If you have an Android or Apple iOS smart phone and your Sky box connected to your Wi-Fi router then you can use your phone to run the Sky+ App. This will let you control all the play/pause/rewind features of your Sky box.
What else do you need to know....
A big trap that people fall in to is buying cheap Ethernet cable. Unless you know what to look for it's easy to get stitched up with Copper Coated Aluminium (CCA) cable rather than the pure copper stuff. CCA is cheap because it uses an aluminium core with a thin anodised coating of copper. That's a problem because aluminium is a poor conductor compared to copper, so baluns won't have their advertised ranges. The second issue is that aluminium is fragile. It breaks easily if the cable is bent or pulled too hard or stood on. It also makes putting on the network plugs a complete PITA. It is possible to break a wire when crimping the plug, so you then have to start again.
CCA also rears it's ugly head in HDMI cables too. Have you ever wondered just how some Ebay seller or Amazon can sell a HDMI cable, pack it and pay for postage and still make a profit out of a £1.99 sale price? That's because what you're buying is this stuff and not 100% copper conductors.
Hope that helped. Hit the Like button if it did, thanks.
Great responses thank you
I just did a test with co axial cable as I had a fairly long wire and magic eye kit I found and it does the job.
Tv is 2008 LCD so maybe quality isn't as noticeable as it would be on newer led
Not sure I fully understand the baluns method - any illustration of connection?
Long hdmi cable is option if I ever change the bedroom tv
Thanks all!
HDMI modulator. Can feed umpteen sets via coax. Sets needs to be HD, MPEG 4 capable. Most modern ones are, Freeview HD capacity not required.
I have an issue because I have
Lounge w/ tv Sky virgin TiVo and a vhs player for modulator purposes plus free view aerial
This feeds bedroom and kitchen in such a way that I can watch freeview sky or virgin in either bedroom or kitchen.....
With this modulator how could I set it up so it's the same?
It depends whether you want both Sky and Virgin in HD or if you're happy with Sky via RF2 Out.
The modulator takes one input (via HDMI) and converts it to a channel that the receiving TV can pick up. This is mixed with the RF signal from the aerial (digital) and any analog signal from the RF modulator that gets mixed with it. In this way you can have Freeview, Sky and Virgin all coming via a single aerial coax. The selection of what to watch is then made by selecting either the analog tuner for Sky, or the digital tuner for Freeview/Virgin. On digital it's then a matter of selecting the appropriate channel.
If you want Sky to be in HD then you'd need a second of Winston's modulators. These can be cascaded so as to add another channel to the signal from a modulator already installed.
You could it an HDMI switch on the input. Some are self sensing and would switch to whichever box was on either Virgin or sky.
True. But you couldn't have both Virgin and Sky on at the same time by using a switch. If there's only one occupant in the house though then a switch would work. It's not really the answer though if there's a family.
