Hi There
I have a WB240RSF which is working, as in it will produce hot water & central heating. However if either hot water or heating is demanded the boiler will fire up as expected but then proceeds to drop the burners & reignite continually throughout its use. As I say the water gets hot or the rads get warm as expected, but the boiler will click away; & this is something it has only done recently. I can only think that the boiler believes that it is getting too hot for a split second because the water temp does vary as the boiler burner goes on & off?
I have a good understanding of my boiler having changed the diverter & water to water exchange in the past but cannot locate this problem? Can anyone suggest things to look for?
Thanks in advance
Thanks in advance
