WC Pan
17 Dec 2006
Tyne and Wear
My trusty old Armitage Shanks toilet is showing signs of wear on the internal bowl area. The surface of the china is rough and becoming harder to clean. The problem I have is that the original wc has a 90 degree outlet to the left which connects to the soil pipe. All the new wc bowls in the shops have a straight outlet.
There is no room to fit a 90 degree bend to the new bowl without the bowl coming too far from the wall.
Does anyone know of a wc maker that does a bowl with 90 degree bend outlet. :?:
Just buy a new craapper - its much simpler.
Hope this helps!
Scruffle
Just buy a new crapper?
I thought my original post implied that I want to buy a new one. But one with a 90 degree bend instead of a straight outlet.
Words mean many things to many people. :?: :?: :?:
go to your local plumbers merchant "s" trap pans are still availible
you should be grand
As a cheap and practical alternative, buy a macerator and plumb into bath/hand-basin waste outlet. You can then do away with the old toilet waste altogether.
Hope this helps!
Scruffle
