HI,
I am stripping the wall paper of all the bedrooms of my new house in order to paint them. One of the walls has got a crack in the centre of about 45 degress although not to big (about 80cm) and I have removed the plaster and exposed all the bricks in an area of around 0.7sqm. It is part of a doube wall as it is the side that separates from the extrior of the house. If you look from outside you can see that the crack has also afected slightly the extrior wall. Now going back to the internal wall with the crack I noticed that the cement that were used to join the bricks is really soft (I could just remove it with a nail If I wanted). I have two questions:
1-Is that normal or is the cement old and has weakened over time?
2-I can not budget for a profesional to come and fix it for me, not at the moment anyway, so I am looking for the best repair i can do my self. I am thinking to just fill up the hole with some mortar and then skim it with plaster or something similar
THe house is a 1930 although I ignore how old the walls are.
Does this sound reasonable or has anyone got a better suggestion?
Many thanks,
North
Many thanks,
North
