I posted a few days ago about a small 45 degrees crack in the inside wall of a small bedroom (the external wall seems OK). Unfortunately while removing the rest of the wall paper I realized that the crack extends more than one meter through the old cement which is quite soft and the bricks in that area look a bit loose.My first though was to re-plaster the whole wall but as the wall looks weak someone suggested to remove the old plaster and to screw some plywood or MDF sheets along the whole wall to increase its resistance and them skim over. I have seen in B&Q some 18mm plywood which I think can to the trick better than MDF although I want to make sure I do not break any building regulation. Anyone has got any advice?
