Weed killer for block paving
17 Apr 2007
I'm on with yet another pressure washing of the driveway block paving which I'll seal with sand.
Does anyone know of a weed killer, in powder form, I can mix into the sand to prevent weeds for a couple of years?
I know the ideal solution is geotextile under the paving but the house builder ('93 ) didn't bother laying any.
Membrane under paving dosn't stop weeds not what it's for the weeds grow in the joints good maintenance is the only cure
Use Pathclear
and don't disturb the sand (e.g. by raking, weeding or jetwashing) or you will have to apply it again.
It's too stop sub grade an sub base mixing nothing to do with weeds they will grow in the sand layer and joints
I was plagued with weeds for years. The weeds grow from the top down. Air blown spores/seeds get into the sand and take root. I had some success mixing kiln dried sand with cement - approximately 50:50. Brush it in dry and then water, then top up.
Guy who laid my drive said the best way to prevent weeds was to sweep it regularly. He reckons the seeds get swept up/out and don't get the chance to take hold. Unfortunately I have a long drive and cant be arsed to keep sweeping it as regularly as I should, although it does appear to keep the weeds down.
Well if the No Grow stuff mentioned above impedes the germination of weed seeds, its one to consider.
I'd likely pay the £4 delivery for x2 20KG bags since the nearest Wickes is about 20 miles away.
