The set up is as follows, i have a pump drawing water from borehole to a storage tank. Storage is c3 feet above ground and i can't move it.
I have a second pump from storage tank feeding domestic water sytem. When running any tap the water is a little stop start now.
Previously i had a pump with an attached accumulator that i believe evened the water flow and their was no stop start. This pump set died and was replaced with just a pump.
For most applications there isn't really a problem, but the shower doesn't like the new set up. So....
Short of buying a new pump anyone have any suggestions?
My feeling is that the cylinder acts as a buffer smoothing the flow and its reintroduction would be enough?
The system worked for years so something must have been ok
What i had before was sort of like this
http://www.pumpsukltd.com/StockItem...roductID=1158&oRef=-1§ion=2&Item=unassign
