wet dash walls
4 Nov 2007
My walls are wet dashed white. They are quite clean apart from some areas where roof drains have been leaking slightly. Just moved in, so have fixed the leaks - would now like to clean the walls a bit. Would a power jet at a safe distance do the trick - can you recommend any detergents?
A jet wash will probably take the paint off.
Use a mild detergent or if mould, a fungicide solution suitable for external walls, and a soft brush
