wet plugs
18 Oct 2009
Herefordshire
friend has nissan aimera 1.4 ten years old,he replaced battary £80. :cry:
alternater checked ok.still difficult to start.
removed plugs,found to be wet,not from petrol, but moisture :?
any ideas please thanks :)
do they still do the wet start stuff from halfords?
or iirc you could use wd40 but again iirc it can flash up quite a bit.
but only do this once you have found more research on this.i remember a m8 doing it(he was a mechanic)as im not do this at your risk.
thanks for reply
yes, he uses car every day to work.
mechanic checked alternater,due to flat batt. he did say started ok on way to work , but trouble starting after work.each day ,strange.
If your mate is sure that the plugs are wet with moisture - and its not unburnt fuel - he needs to look at the inlet manifold gaskets.....the manifold is heated by coolant and its about the only way that moisture can get in. Apart from a blown head gasket, of course! Cheers John :)
Just a way to help see if its a manifold problem.....look at the 4 inlet ports in the cylinder head when the manifold is off....usually they are uniformly black. If water gets in, they often look spotlessly clean! Best of luck mate John :)
