wet room and boiler query
12 Nov 2010
I have a problem that I hope can be resolved without too much expense.
I have a Bosch 28I junior that is running the DHW and heating in a holiday cottage (kitchen sink, and two shower rooms)
The problem is that when the shower is in use the hot water periodically coolsat the shower head (as if the hot water is being used else were)
I have installed a pressure reducer on the cold feed and set it as low as I can without effecting the flow through the shower too much but this has had little effect.
I presume the problem to be the size of the boiler water flow so I think the solution is an electric shower unless I am missing something.
Any advice appreciated.
Cully
