Apologies for asking what is asked over and over but when I do a search here, the returned posts are so old that I suspect new products will have overtaken them. I've read a lot of them but there seems to be different approaches and I'm getting a bit confused by what's needed for a bathroom. The shower area will be level access/ceramic tile like a wetroom. Size is 3.5m x 2m and is on the first floor.
Floorwise - I've pulled up all my floorboard and I'll be working up from the joists.
NoMorePly straight on the joists has been recommended but believe there's a difference between waterproof and water resistant, and cement based products like NMP, Hardiebacker and Aqua Panel are merely water resistant i.e. water will not change the inherent structure of the material but it can still pass through and saturate what's behind it. That makes me nervous. Whereas I believe Kerdi, Wedi and Marmox are waterproof but they can't go straight on the joists, there'd have to be a substrate.
* If I do use 22mm NoMorePly do I also need to tank? (Assuming I follow the NMP installation instruction as regards taping joints etc)
* If I do need to tank, which is better, a roll/stick-down mat like Impey self adhesive, Ditra/Dural with adhesive or a paint-on one like Mapei?
* As the mat seems to be a decoupling membrane, is that in all circumstances preferable on timber floors?
* If I do need to tank/decouple could I just used a wood substrate and no backerboard? If yes, WBP, OSB or marine ply?
* If backerboards need tanking anyway would an 18mm ply base plus 6mm backerboard be better than 22/25mm ply?
Wall wise - I've got 2 bare internal stud partition and 2 exterior brick cavity walls that have a plaster scratch coat.
For the exterior walls I was thinking of dot and dabbing foam insulated tile backerboard like Marmox where there's going to be water. Should I also tank this with roll-on mat or paint-on tanking?
* For the interior walls, which are away from the bath/shower area can I just tile on to moisture resistant plasterboard?
* Finally, in a bathroom and away from the wet areas is there ever a time where you can just use ordinary plasterboard which can be skimmed and painted?
Sorry for so many questions but thanks in advance for any help.
