Wet underfloor heating on existing uninsulated/ no dpm'd concrete floor
21 Jul 2004
Hi all,
I want to install wet underfloor heating on the ground floor of my property. It's a 1930's build, all of ground floor is solid concrete floor. Assumed that no DPM and insulation as its original build.
What are my options to install wet underfloor heating? I have the ceiling height so can afford to lose 4 inchs or so.
I'd rather not have to dig up the existing to get the dpm in and make a new slab.
What are my other options?
I would say that you can do that. WITH insulation min 75 mm.
BUT is it worth all the bother???
Tony
Do i need to install the dpm under the slab or can it be ontop of existing slab andthen insutiolation boards ontop then screed?
So its fine if I put the DPM ontop of the existing concrete slab? Put 75mm celotex double side foiled back. Run my pipes ontop of this and then 60mm screed?
Is this acceptable practice?
