- Joined
- 27 Oct 2020
- Messages
- 22
- Reaction score
- 1
- Country
The back of the house is getting rising damp and I can see the black plastic lining is flush with the ground. Masonry paint has been previously used. But no effect
I’ve just installed dry rods internally but wondering if I need to address the continuing problem
should I cut away the ground and overlap some plastic then cement it back, to create a seal up the first 2 courses?
or is the dry rod sufficient please?
not looking for dramatic problem causing replies: just after hints and tips to work with what I’ve got please and thanks.
I know it’s a building and needs professionals but I’m broke. Technically minded. Doing ok so far. Have required tools I think. If there’s a solution or some technical minded tricks they would be greatly appreciated!
tia
