Going to install 'wet walls' to shower area for first time. Should wall behind be weterproofed first n if so what with? Also what is best way to fix the wet wall to the wall. Any advice on sealing also appreciated. Thanks.
im from canada wet walls is new to me do you mean tiles if so do it right strip to studs, apply backer board or cement board screwed securley to studs don't forget to insulate if needed cement joints to smooth finish use epoxy cement to apply tiles and grout use sealer for grout as per mfg. instructions
crazycanuck
Moderator's note:
Hello, Crazycanuck. If you use punctuation marks and paragraphs, it will be much easier for us to understand your posts.
