I'm planning on fitting a wetrooms in a house conversion. There is a lot of conflictiong information online but I have the following plan and comments from anyone with experience would be most welcome;
1- Existing timber floor joists (Room 1.9m x 1.7m)
2- 9mm to nothing firing strips laid ontop of joists in 1 x 1m area to create fall to drain.
3- outside this 1x1m area a layer of 9mm ply to match top of firing strips
5- a further layer of 18mm ply over the whole floor, including sloping down to the drain.
6- GRP fibreglass layer lapped up the walls 1 brick course
7- tile and grout onto the fibreglass
Therfore max floor thickness = 27mm + tiles
(existing floor boards are 21mm)
So the questions;
1- The walls have been stripped back to brickwork already, and I'll use 'aqua cote' or similar waterproof board before tiling onto it. Does the fibreglass go down and then the wall boards, so they sit in front of the fibreglass, or does the board go on the walls and then the fibreglass is lapped up it?
2- I've got are Purus Minmaxx floor drains, does anyone have experience of these?
3- A company spoke to today said that so long as your toilet and sink are outside a 1.5m radius from the shower you don't need a shower screen. I was going to take a leave it and see approach to this- I can always add one later if he is wrong. Just thought as I was asking questions I'd see if anyone had experience otherwise.
So the questions;
