wf541 Reset code
16 Jun 2011
Armagh
I hope someone can help for i am lost with this one
I have had to replace the circuit board on a wf541
I think it's asking me for a reset code can someone help please desperate thank you
Reset code ???? What's it's doing or what was it doing prior to pcb replacement
Flashing on and off button
3 light down the left side
Cpb board was wet and had frozen
replace the board cpb
Where did you get the pcb from , it has to be configured to that mc by commercial code and serial no. the board you got was poss blank and had no software loaded on it.
I had taken this from another machine so once you remove this board
To put into another machine of the same make and model it has to be configured
If I send this board to be repaired I am told it doesn't need to reset i'm lost with this
You can't configure it yourself if you send it away for repair they will do it for you. If you have taken it out of another mc was it the same motor in that model as well. 3 diff motors 3 diff codes for that model
So the best thing to do is buy the smart card for to do this
I have noticed there are three different cards could you please advise
Which one would be the best.
There is one in particular it costs between 100 to 130 pounds could you please advise
You need a smart card reader as well cost 130 plus the card as well that's a tenner. Hotpoint will do the whole job for 100.
