whashing machine problem help!!!!!!
18 Nov 2009
Newcastle upon Tyne
please could somebody help me. i have a hotpoint aquarius 1000 washing machine and the belt keeps falling off does anybody why this could be happening???
belt loose ,drum bearings gone ,motor loose ,pulley warped take your pick . :)
its not a wma by any chance is it if so the rear drum surport has taken out the bearings .
9 years old if the inner drum lifts up by a few mm then time to scrap it bearings shot any brown rust marks on the floor underneath the mc .
when i put my hand right at the back of the drum it does not lift up but it does at the front. when i turn the drum manually it makes a grinding and banging noise.there arnt any rust marks on the floor under the mc
pull the inner drum up from the front just by the seal, back is no good .
do yourself a favour strip mc down to see if you can get the bearings out ,it might be a broken drum surport ,then get the parts needed ,there is no point it buying it and finding it needs more parts or you crack the drum getting them out . then you have wasted your money ,part no for bearings is 168970 by the way .
