The Ring Upstairs and Ring Downstairs are each connected to a 32A MCB, typically using 2.5mm Twin & Earth cable. But the maximum current that a 2.5mm cable can handle is 20A, so how does it work with a 32A MCB?
Is it because a ring circuit has two wires in parallel, so in effect you have a (20+20) = 40A coverage. Wouldn't it be better just to use 6mm Twin & Earth cabling?
