This float valve is fitted to a Royal Doulton WC cistern of approx mid-1970s vintage. The owner complained of an overflow drip; I tightened the adjustment rod that pushes into the centre of the diaphragm assembly, and tightened the large locknut around the perimeter of the assembly, to some effect, its not overflowing as quickly but still getting there.
The push rod looks as though it may be fouling on the red plastic and not pushing the diaphragm in fully, leading to the overflow. I plan on removing it and shaving the outside of the rod so that it fits into the diaphragm hole a bit easier.
If this doesn't do the trick, it suggests the diaphragm may need replacement - I did the rounds of the local merchants today, and all I got was "Never seen one like that before" and a selection of shaken heads and breath drawn in over teeth ........
The only diaphragms I could find that looked remotely big enough came from B&Q - an Armitage Shanks type, and a Torbeck
I'll take any suggestions on what make the valve could be, and on the possibilities of finding a suitable matching diaphragm ..... and any other pertinent advice, naturally!
Regards, Graham
Regards, Graham
