if you can give me a reason why not to install one then i'm all ears............
To allow the quickest possible heat up time for the cylinder and to give the cylinder flow priority.
As Doitall states....
Valves are only used or needed for circuit balancing and isolation.
Most systems are piped in 22mm
, without a restriction to primary return central heating circuit will suffer 'short circuiting' when both heating & hot water are calling , most systems are fitted with 5 metre head pumps
which just adds to the problem...............when installing two seperate boilers for hot water/heating then lockshield valve is not required , same deal when installing two seperate pumps for heating/hot water....................lockshield valve will help isolate part of system when 'snatching' system for pump/motorised replacement , DON'T TRY THIS AT HOME!! , also applies to the guys less experianced , seems to be quite a few keyboard jockeys on here that get their info from books & internet.
