What fixing for battening wall?
If you have a lot to do I would get a box of rapier star fixings, you can drill straight through the wood into the wall then put your fixing in 120mm will do.
Can you bond insulated plaster board directly to the wall.
Yes you can, I did it in my garage conversion, then tape and joint filler the joins for a perfect finish after some sanding down. Very easy with a little effort.
