I am fitting a new kitchen cabinet where the boiler used to be and im unsure how to fix it. The brackets have holes for 6 screws. I know i already have some grey plugs, brown plugs and an assortment of 2-3" screws. think i also have some hammer-in fixing which might be 3"?
cabinet carcass is 400mm wide and the wall construction seems to be plasterboard then breeze block then brick. there is about 1" from the outer surface of plaster to the breeze block (house is about 20 yrs old if that helps) how deep into block do i need to go or do i need to go into the brick!
thanks in advance
thanks in advance
