Hello,
We had major plumbing work carried out last year. Mains pressure is very high here (10 Bar I think) so the contractor fitted a 3 Bar limiter after the stopcock. I would have expected (possibly incorrectly) that this would 'regulate' rather than 'limit' the pressure to 3 Bar. I come from an electronics background, so anyone who understands what a constant current source does will understand what I mean - it will keep the flow the same under a changing load.
So, when I open a tap, I would have expected the limiter to ramp the flow up to compensate. What actually happens is that I get an initial gush from the tap, but it then tails off to a relatively pathetic flow. This means filling a bath takes 20 minutes. Worse, it means that whilst that bath is filling, other taps in the house become next to useless.
Is it really to be expected that my wife can't wash her hands upstairs whilst a bath is running, or that I can't fill a kettle whilst someone else is using a hosepipe? I have never lived in a house before where this is the case. Is the limiter faulty, or is this normal behaviour?
NB: All our water is off the mains, there is no cold tank. The hot water cylinder is unvented, so again is using mains pressure to feed the taps.
Thanks.
Thanks.
