Connecting a hand basin with 10mm speedfit pipe.
5 Feb 2008
Edinburgh
I want to connect a wash hand basin in a little loo and have mains pressure hot and cold limited to 3 bar with a pressure reducer.
Could I feed this in 10mm speedfit, as the tap has 10mm connectors and the running of the pipes would require a fraction of the work due to the flexibility of the smaller pipe.
If so, how long could I run in 10mm whilst still retaining a good flow at the taps?
Any constructive comments gratefully received.
12 Aug 2008
Lancashire
yea it quite execptable to run 10mm from a pressurized system, in a little loo your not going to need big volumes of water, so the lenght of pipework won't matter.
