You have the freedom to switch suppliers, within days, your supplier must advise you in advance of any changes in your tariff - so what's the problem?
I went, in hindsight in error, to British Gas EV rate. Yes, could leave, but a £75 charge for leaving, resulted in my remaining until the term had expired. I note some Octopus tariffs also have a leaving charge, but not as high.
I note a variation in both start and stop of off-peak, with start times from 11:30pm to 2am, and finish from 5am to 7:30am. With no solar or no battery, it would not matter, but with solar and batteries, one does not want to pay to charge a battery, then have to export that power for less money. 11:30pm to 1am would suit me, but clearly not there to suit me, it is to suit the supplier.
But for someone like me, who can have a smart meter, and can afford solar, and batteries, it is not really a problem, annoying to pay over the odds, but not a problem.
Where the problem lies, is someone living on a shoe string, being told their storage radiators will stop working, and there seems to be nothing published to tell them how to get around the problem.
If before the 11th hour, we know how to do it, then we can advise, but "suitable meter" does not really help anyone.
For my tumble drier, it takes around 2.5 hours, as I go further from the start time, it moves from ½ hour to 1 hour increments, and one of the Octopus tariffs was only for 3 hours, 2am to 5am, so to set it to run in that slot could be a challenge.
The off-peak rate of 17.1p/kWh also seems a bit high, when other tariffs have 7p/kWh 23:30-05:30 much longer and much cheaper and also cheaper standard rate 27.26p against 28.5p standard and 39.9p peak, it seems EV owners are being given preferential treatment, although more likely because Octopus can control the EV charger.
Those with solar inverters that allow the supplier to control when batteries charge and discharge are also given special rates.
Your smart meter will have a fixed off-peak 7 hour period from 00:30 to 07:30. This time period takes place according to Coordinated Universal Time (UTC), so during British Summer Time (BST) the 7 hour period will take place between 01:30 and 08:30. This may differ from your existing off-peak period on your current non-smart meter.
Octopus Energy's Flexible Octopus Economy 7 tariff has a peak rate of 34.44p/kWh and an off-peak rate of 14.45p/kWh as of May 1, 2025, at 17:00:05.
That is one heck of a price for electric. I pay 25.37p/kWh and 68.17p/day standing charge. Considering the 34.44p is summer and winter, it would seem those with storage radiators are being ripped off. I would think most people would be better off with panel heaters, and only heat a room as and when required.
But I could afford some panel heaters
but often people with economy 7 are not flush with money, I would need 15 for this house, that's £850, OK a large house, but my daughter would end up with one and carry it room to room, as to heating a bathroom, maybe need to go back to old tin bath on back of out house door?
