What is ballast!
12 Aug 2009
London
this is my first post! and what a riveting one it is also!!
can anyone just explain what ballast is to me, and what is the difference between this and sharp sand.
what would you use ballast for, i know you can use it for concrete but do you use this with sharp sand or what?
cheers!
Welcome firstly.
Secondly the post should be in building or general diy section ... so .... tut.
Thirdly ballast is a sand and stones/chips mix, typically 10mm to 20 mm size stones.Mix this with cement and you get concrete.
Sharp sand is sand with finer aggregate in it say up to 6mm - typically used for laying slabs, blockpaving etc
Hth
cheers steve
but why and what reason would you use ballast over sharp sand in concrete.
cheers
Sharp sand and cement is used for jobs such as floor screeding i.e a shallow depth.
Ballast is used for used for deeper depths and in re-inforced concrete.
Ballast is the main ingredient in concrete and is a proportional mixture of sharp sand and aggregate.
Concrete is made up of 4 parts aggregate, 2 parts sharp sand, 1 part cement and water. The bit that is aggregate and sharp sand is known collectively as as 'ballast' and is sold as such ready-mixed in tonne bags etc.
As said previous, sharp sand (also known as screeding sand, concrete sand, grit sand) has uses in its own right. It is a softer version of ballast and is used for floor screeds , slabbing mortar, mixing with loamy clay soils, and some masonry applications.
Love the concrete under my wooden floors - 1920`s style .....Pebbles up to 1 inch dia. :lol: . Dry Lean ....thankfully still dry
