What is involved in an annual oil boiler service ?
4 Jan 2008
Hi
I have an oil boiler which I need to have serviced.
I was just wondering what needs to be done ?
I take it that there are filters and other parts that need to be replaced ?
Cheers :)
Basically it is replace the nozzle and check the burn is ok.
Baffles can need cleaning but not if the boiler has been burning correctly.
Check and replace oil line and any seals as required. Also check tank and filter.
Oil boilers are usually very robust.
Check that carbon monoxide is not and is not likely to leak in to the dwelling and kill the occupants.
:D
