    Dismiss Notice
what is the best insulation to use between rafters
Discussion in 'Floors, Stairs and Lofts' started by seebo, 19 Mar 2018.
  1. seebo
    seebo
    6 Mar 2018
    25
    Thanks Received:
    Country:
    Our loft is very cold on a windy day you can feel the air gushing through. the floor is insulated with rockwool I am not sure what to use in the rafters to make it warmer and stop the wind coming through.
    I have seen leaflets about variou foil wraps (superquilt) i dont know whether this would cause condensation. or should I just normal insulation on a roll and pack it in between the rafters.
    I would appreciate any feed back, thanks for your time.
  2. freddiemercurystwin
    freddiemercurystwin
    21 Jan 2007
    19,861
    Thanks Received:
    2,218
    Devon
    Country:
    The roof above the ceiling level insulation is supposed to be draughty, you don't need any insulation between the rafters.
  3. Sponsored Links
  4. geraldthehamster
    geraldthehamster
    7 Feb 2010
    2,973
    Thanks Received:
    320
    Country:
    A draughty loft is a dry loft
  5. seebo
    seebo
    6 Mar 2018
    25
    Thanks Received:
    Country:
    I was not aware its normal to have a draughty loft. :unsure:I thought we had a problem!! thanks for the feedback, it has saved me alot of work.
  6. Sponsored Links
  7. geraldthehamster
    geraldthehamster
    7 Feb 2010
    2,973
    Thanks Received:
    320
    Country:
    "Ventilated" is probably a more accurate word than "draughty". Ventilated so that any moisture or condensation can dissipate.
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
