    Dismiss Notice
What kind of tradesmen would replace phone sockets?
Discussion in 'Audio Visual' started by essexmick, 7 Sep 2014.
  1. essexmick
    essexmick
    25 Aug 2014
    94
    Thanks Received:
    Essex
    Country:
    I've just bought a house, which has phone sockets in almost every room.
    Many look very old and are hanging off the wall, sat on the floor etc.
    I thought it might be nice to get new ones properly fixed to the wall.
    What kind of tradesman would do this?
  2. Sponsored Links
  3. cajar
    cajar
    12 Mar 2011
    1,720
    Thanks Received:
    135
    Glasgow
    Country:
    telephone engineer is best, but most electricians would be able to do it as well.
    • Thanks Thanks x 1
  4. Sam Gangee
    Sam Gangee
    24 Jan 2003
    1,875
    Thanks Received:
    284
    Cheshire
    Country:
    • Thanks Thanks x 2
  5. Lucid
    Lucid
    10 Sep 2013
    1,753
    Thanks Received:
    1,016
    Cheshire
    Country:
    Based on personal experience, I wouldn't trust the average electrician with anything IT or AV related. Not unless you have a few recommendations from trusted friends that he knows what he is doing.
    Go for a telephone engineer.
    • Thanks Thanks x 1
  6. krakus
    krakus
    8 Sep 2014
    Thanks Received:
    Sussex
    Country:
    Agree with Lucid.
    Best option would be to look at adverts listed in Gumtree, Friday Ads etc for Telephone Engineers. Chances are they are current or ex BT and will know what they are doing and use the proper cables. Electricians will do the job but often use incorrect (have seen standard electrical cables used - I kid you not!!) or cheap cable.
    • Thanks Thanks x 1
  7. ericmark
    ericmark
    27 Jan 2008
    17,941
    Thanks Received:
    1,670
    Llanfair Caereinion, Nr Welshpool
    Country:
    As an electrician sorry have to agree. Years ago all that mattered is for the telephone to work and there were three wires if you got 2 and 5 swapped the bell did not work and it was simply a case of it worked or it didn't.
    However today with fibre broad band going down the cables it really does need special test equipment which the standard electrician will not have.
    OK I did Cisco Systems and so has my son but we are the minority and even though we know what should be done we still do not have test gear to test once completed.
    I had to disconnect some in my house because a neighbour fitted wall lights on the other side of the wall to my telephone which causes a 50 Hz hum on the line. It is so easy to make an error like that.
    • Thanks Thanks x 2
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
