B
Bambergaspipe
Is it the kw number im looking at,
Basically , yes, if it`s electric the higher the kilowatt the better the shower in a nutshell.
I have found an 11kw one, which i might order later on
THANK YOU!!![]()
Also remember that the more expensive ones are thermostatically controlled I believe where as the cheap ones are not.
Mira ATL, Mira sport thermostatic. I think they have some additional temperature compensation internally for when someone else draws cold water, they react quickly to prevent any uncomfortable fluctuations
they would be thermostatic as opposed to electric showers ? do you know the difference between a thermostatic shower and an electric shower
Don`t be shy just raise your hand in front of a whole nation of website users and say `` I`m a tw*at``. Nothing to be ashamed about. Good for you, builds confidence..
Thermostatic just means that there is a mechanism inside whichever shower you choose to quickly regulate the temperature to a set level (when flow changes due to fluctuations).
