Hi folks
I am planning to build a coffee table of approx. 110cm x 70 cm. I am hoping to give the top of the table, a finish that looks like granite or quartz. I don't want to spend in buying a real granite slab.
Have you seen the black quartz worktops in MFI or B&Q with the silvery bits on the surface. That is the kind of finish I am talking about.
I found one solution, i:e; using the fireplace back inserts. But they come in the sizes of 930mm x 930mm or 1.3m x 30cm.
I am just hoping some one can tell me what material to use and where to get it.
I need a 110 x 70 cm sheet to use as the surface over an MDF or plywood board.
Thanks for help.
sk
Thanks for help.
sk
