I have a bathroom that was traditionally two rooms, a toilet and bathroom which has long ago become one room with the stud wall removed.
This has left two windows in the room being different sizes and heights within the room.
I have planning to remove both for one long window.
The bathroom is on the first floor (last floor) and above the lintel there is only about 2ft at most of brickwork (solid double red brick) and a slate pitched roof.
The span is going to be 2000mm with 2400mm lintels being used. A long PVC double glazed window with then be installed after. About 650mm in height.
I am going to fit two side by side, but should I go for the 100x140 or the smaller 100x65.
Currently thinking the larger items.
I had considered 7x4 steels but now think that's OTT.
Building control will be inspecting this as it's part of other works due a little later.
