what size of central heating pump
17 May 2006
placeing new boiler in shed at side of house & going to pump water back to house
the highest point is 4.5 m which is about 25 - 30 m from boiler
my prefered choice of pump is grunfos
pipe size is 25mm
The boiler installer should be able to spec the pump.
It depends mostly on the heat load and to a very small extent the boiler.
A Grundfoss 15-50 suits most three bed semis.
Tony
mabe should have said but the water is going to be pumped from accumulator tank which will be heated to around 85c 4 bed room bungalow with 10 rads
thanks
