What this calculation
If X is a negative number then you've written down the original equation wrong. Maybe it should be X^2 (squared)?
Similarly the thread title could have a hidden mistake in it.
"What this calculation URGENT !!!!!"
But if one didn't know what an 'operator' is, probably one would also not formulate a real-life problem by means of an equation. Looks almost like someone was sitting an exam, couldn't figure out the solution, and posted it URGENTLY on the forum...
Or needed to hand in a work sheet the next day.....and had the answer given by you guys marked incorrectly.
I doubt that he did. As you go on to say ....
Sort-of - although if he knew what the answer was meant to be (at least, knew that it was meant to be negative), he can't have been sitting the exam. Perhaps more likely a 'homework question'.
Kind Regards, John
