What to do with the cavity?
22 Nov 2009
Oldham
I'm building a small double storey (habitable) porch/infill and I'm a bit stuck with the cavity.
It is, certainly for me, a bit hard to visualise so I hope my images help:
The new door will go in the opening at the front, the outer skin of the inner right hand wall will be removed behind the down pipe and it's the bit in front of the downpipe that I'm stuck with. I was originally going for option A, extending the inner skin with a nib - a messy job toothing bricks in with our lounge on the other side. I'm now wondering whether option B might be acceptable? To me it looks technically wrong, in terms of thermal bridging and damp penetration but it would be a lot easier and would retain the strength of that external corner.
Alternatively, if there's another option I'd be interested to learn?
Edit: I did consider option C, seems easiest of all (and the reason for removing the outer skin is to maximize internal space in the porch), I'd just need a longer lintel over the door to reach the inner bearing, but I would end up with a 150mm section of uninsulated single skin brickwork (could it be lined with celotex?)
D - like A, but in timber, insulated and returned around to the external leaf, and a longer lintel, or if the dimensions don't mean lots of cuts, in brick with fishtail ties every four courses - and still a longer lintel
B is just wrong, and your last idea despite being difficult to do won't match the opposite jamb unless you replicate the awkward arrangement.
Thanks Woody. I've gone for plan A/D.
It's about 200mm from inner skin to door opening so I'll probably do it in masonry with the fishtail ties. The lintel I had for the job is now too short and the course heights are different so I'm going to use a longer concrete for the inner and a shorter single leaf for the outer. Managed to get a full brick out of the inner leaf for the lintel with only minimal collateral damage inside!
