Hi all
I live in a 3 bed 1930’s semi in N.London which still has (from what I’m told) a Gravity fed system. Got a copper tank in an upstairs cupboard with a cold water tank and heating expansion tank in the loft. All 11 radiators in the property were replaced only 3 years ago for modern efficient ones.
The boiler is made by Potterton (floor mounted) and approx 9years old which is linked to a Waterside MC2500 water softener, which is connected to a pressure reducing valve. The main water coming into the property is via the new blue poly pipe (Installed 2 years ago)
I’ve been told that I should have the following work carried out
1. Replace the boiler for a more energy efficient self condensing boiler and move to the far side wall (in my kitchen). Convert from Gravity fed hot water to pressurised – all pipe work is under solid floor and will have to be extended.
2. Replace the old (25yrs plus) copper tank for a modern one and move it to the loft and free up the cupboard for storage.
I’ve also been warned away from going for a combi boiler as the property has solid floor throughout and access to any old heating pipe work will be very difficult (and therefore expensive).
Ok guys hope I’ve covered the background needed, on to my dilemma:-
1. Should I use the opportunity and have a Megaflow linked to a new self condensing boiler?
2. Can the Megaflow unit be installed in the loft? (Any negatives of doing so)
3. Can someone recommend a decent installer in N.London? (had one company in who just said what do you want and we’ll do it – no advice / recommendations or anything)
Sorry for all the questions….I’m lost when it comes to plumbing.
Thanks in advance
darms
Thanks in advance
darms
