What type of shower???????
23 Oct 2007
London
I have a gravity fed hot and cold water system with cold tank and hot tank. I have a showerforce 1000xm at the moment but it has just gone wrong and i wanted to know what would be the best type of shower to replace it with please.
Thanks and look i forward to some suggestions
Pete
you can use the newteam 1000xt it is just thermostatic as opposed to your model which is manual.http://www.tapstore.com/acatalog/copy_of_New_team.html
The only thing to be cafull of is if your hot and cold come in the left hand side there is not a replacement but if there enter on the right that will be fine.
the other way to check is if you have a transformer on the power cable then there is no replacement but if there is none then you are fine.
here is a link to the install instructions.http://www.newteam.co.uk/projects/cnew001/web/PID.nsf/webresources/404-0125.PDF/$File/404-0125.PDF
Good Luck
Do you want a complete new shower ?, whats your budget?
I have a mira magna and think its great, and no need to have any pipework in walls.
