I've found so much varying information and nothing for my specific scenario. I'm having a single storey rear extension with 3m bifolds out the back. Warm flat roof.
100mm block on each skin and 150mm cavity w/ full fill ins
4m (3.65 internal) out and 5.7m across (5m internal) - the ceiling joists at 9x2 running the width of the extension, so will not be bearing either on the rear of the existing house or over where the bifolds will be.
In this case, I don't know whether to put a 152x89 steel in above bifolds with an 8mm welded plate to catch the outer blockwork, or whether this is just overkill for something which will essentially just be taking 2-3 courses of blocks above the bifolds? I'm just concerned about any deflection w/ a standard duty cavity lintel pinching the doors.
