Garden Room Lintel Above 2.4m Wide Bifolds
23 Apr 2022
Evening,
I'm putting together a materials list for the build of a 7x3m Garden Room & home office/Storage shed at a roughly ⅔/⅓ split.
I've submitted plans to go "up to" 2.9m high which have now been approved. This gives me slightly more freedom with the build.
As per the title we're putting Bifold doors in (2.4m wide). I've hit a bit of a stumbling block with what Lintel to use above them.
Build is timber frame with 2"x4" C24 walls.
Knowing a single 2"x6" C24 would exceed the unsupported span requirements, my initial thought was two 2"x6" bolted together as the lintel, but worried about potential sag under the weight of the Bifolds as they're likely to be top hung.
Whilst I have the height flexibility to go up to two 2x8s or even two 2x10s if required, the approved 2.9m height is a limit rather than a target and want to remain as short as is feasibly possible.
Above the lintel just warm flat roof.
Question 1 - Any comments around whether two 2x6 bolted together would be sufficient as a lintel for 2.4m wide Bifolds?
Question 2 - Would I be better off with something like a steel box lintel?
Question 3 - If so, any recommendations on what height I'd need (100mm obviously being max depth due to using 2x4 for the walls)
Question 4 - Any other options that I might not be considering given the info above?
Much love
If I were you I would look at the specification sheet (or ask the manufacturer) of the bi-folding door system you plan to use, as it may well provide information about lintel requirements. I am not going to offer any specific advice because double glazing is incredibly heavy and the leverage when the door is open is enormous so if you are dead set on having top-hung doors I think you need to overspecify the bejeezus out of the lintel or get some rigorous calculations from somebody you can hold liable if there is an accident.
Evening,
Much love
Might be a bit cumbersome but have you thought about a timber flitch beam? I.e. your two pieces of 6" x 2" with say a 10mm pre drilled plate sandwiched in?
Bung in a bit of angle iron 150 x 100 x 10
or C section or square hollow section
or a steel box lintel
bifolds need vertical and lateral stability so don’t just think about vertical load.
get bottom hung bifolds not top
