- Joined
- 15 Feb 2008
- Messages
- 247
- Reaction score
- 10
- Country
I’ve got an IDEAL STANDARD WC - sits on the concrete floor / not rear concealed.
It has two Phillips / cross head fixing screws about an inch up from base.
They screw into nylon inserts, through the ceramic.
They screw in horizontally - not downward into the floor.
Does this suggest that there is a concrete mound under the base.
And that the nylon inserts were pushed into the (wet) cement in a rawlplug style.
Otherwise, I can’t figure out what they would fix / screw into.
I’m debating taking the pan out for LVT flooring Vs cutting the flooring to the pan in situ.
Thanks D
Thanks D
