What works best - dust extraction or filtration?
30 Jan 2008
Gloucestershire
I work a great deal with my bandsaw, power files sanders etc.. in my small garage, causing a cloud of dust to appear!
What would be the best and indeed, how do the two options of filtration or extraction differ? to eradicate this problem?
Thanks in advance
they go hand in hand you cant have one without the other unless your talking masks
if you mean a system that filters the air in the room in my opinion they are to little to late
extraction just means to remove from but in this case has been extended to collection and filtration
you need a system that will work with the setup you have
no good getting a 4" hose extractor if you need to exract from 35mm hoses
Thanks for your message.
Some of my power tools and my bandsaw don't have a hose at all!
Does this fact mean an extractor is out of the question?
my rather crytic message you mean lol :D :D
yes you can have general extraction but iff your not picking up 90% off the dust you should wear a dust mask
units that filter the air cant be 100%
to be honest with time the dust settles anyway and the filters can only filter the air that goes through them
if you have a relativly small area you can work from say 18" cubed you could probably build an open fronted "BOX" that would have enough flow from a 4" extraction pipe to catch non directional dust but certainly wouldnt catch dust propelled at 20ft a second
most messy tools have extraction ports built on
