it's been mentioned in several posts this past week..
what is it and how does it work?
enquiring minds would like to know..
Another misleading use of the term "gravity circulation".Not always gravity circulation, a lot of domestic ones were pumped.
On a single pipe system the flow is connected to the top of the rad and the return to the bottom at the other end. The bypass is adjusted to allow a proportion of the flow to enter the radiator via the top connection.
What bypass?
Very rarely see a bypass on a one pipe. That would just reduce the flow cumulatively. In most cases the gravitational circulation works fine with no need to force the circulation within a radiator.
This is an interesting read:
http://www.oldhouseweb.com/how-to-advice/gravity-hot-water-heating.shtml[/QUOTE] had a quick read of some of this, then got a little disheartened "A cubic foot of water at 180 degrees F takes up about five percent space than a cubic foot of water at 40 degrees F".![]()
You misunderstand one key aspect - a cubic foot will be different at different temperatures due to expansion/contraction of the ruler used to measure itThis is an interesting read:
It's called expansion twgas![]()
Everything expands as it gets hotter.
Apart from ice, for a bit anyway![]()
